Bought new door seal and bracket from Appliance pros, everything installed tight, but door wont close without major pressure. is there a smaller seal for this model??
What is the part number for the door seal? How did you find it if the model number you posted does not come up?
Okay the model number on the tag in the diswasher is DU300xr1, when i put it in the website it referred me to Du3000xr1. The diagram on the site matched the dishwaser to a t, so i went ahead a purchased the seal based on the manuel. The part number i ordered was AP3115122.
Thanks for responding, looking forward to your take.
It is normal to increase the door closure force after a new gasket installation. It should lower after a few cycles with hot water and heated dry.
