Brand: GE Profile Dishwasher Model Number: PDWF680R10SS Main Symptom: Wont Start What happens & when: I just replaced the door handle actuator and the door keeper latch. The door currently appears to latch properly however unable to activate the dishwasher by pressing the start switch. Lights are illuminated on the control pad however unable to change the wash setting and there is no light for the start switch. I tried some trouble shooting however nothing has worked so far. Any suggestions?
Thanks for the reply! The lights are illuminated on the control panel however unable to select a different wash option or start the dishwasher. You can hear the latch beep (which is normal) when the door is closed and the lights are illuminated on the control panel however unable to change the selections or start the wash cycle. All wire connections appear to be secure. I’m beginning to think I might have an issue with the circuit board for the control panel OR an issue with the main board.
