Replaced control panel now normal light flashes
Help - the lock button was stuck on and I was told to replace the control board. I just replaed the control board and now the normal light flashes and it runs for a minute and stops full of water. what now?
Replacement parts for WHIRLPOOL GU1500XTLQ1 | AppliancePartsPros.com
Here is a service manual and a tech sheet
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
The above should help you diagnose the problem.
Try different cycle types re: where it does not look at the water temperature, as it may be waiting for the temp to rise tos certain level.
Thanks for the repair manual - it is helpful.
The water is not getting hot. Not sure what to check next.
I would check the heater with a meter to see if it has continuity. Should b3 10 to 35 ohms.
If OK
Check the HiLimit thermostat, should be 0 ohms
If OK
Check that the heater is getting voltage when it should (120 volts)
