Replaced control board wh22x35757 on a GTW680BSJ0WS
Brand:GE
Model Number:GTW680BSJ0WS
Main Symptom:Lights flash, cant set personality, release start it goes black
Error Code (if any): none available
Parts or tests already tried:replaced main board WH22X35757 and rechecked connections, still no way to set personality or error codes… when release the start button, lights go out , hit start, nothing,can only reset by unplugging…need proceedure to set personality to this board any help is appreciated….
Did you do what’s in this?
WH22X35757.pdf (157.3 KB)
[quote=“Etagle, post:1, topic:410934”]
GTW680BSJ0W
Here is the GE Instructions ;
WH22X35757.pdf (149.6 KB)
I have the same issue. The instructions did not work. What else can be done.
I have have the same issue. The instructions did not work. What else can be done?
Based on the info provided you will likely need to contact a GE technician. I do see 3 service bulletins for this model, each having to do with a software issue and update…!
Not sure if one of these are causing you issue, but seems like it is possible.
HL06-17-Top-Load-Washer-Excessive-Vibration-or-Moving-Service-Bulletin-35952 (1).pdf (133.5 KB)
WH98R23015001-SUM-Part-Instruction-37007 (1).pdf (407.6 KB)
Software Update WR98R1967001.pdf (419.0 KB)
Heyyyy, did you ever resolve this? I’m having the same problem and apparently it is rampant based on all the posts I’ve found. Thanks!
