Brand:maytag bravos
Model Number:MVWX655DW1
Main Symptom:not agitating
Error Code (if any):f7 e6
Parts or tests already tried:clutch kit, hub kit
Brand:maytag bravos
I will need more information please. Does it spin? Did you run the diagnostics to find out what the error code is? The more you can give me, the better I can assist you. Thanks
Yes, it spins just fine. Everything else seem to be working correctly except during agitation. It’s like it is stuck. I hear it tring to agitate. I watched a video on how to run an error test and that is where I got the error code from.
That is a motor failure error code. It turns one way to spin,. but the windings going the other way are bad.
