This assembly is part of the refrigerator’s water supply/filter system. I would approach it this way:
Unplug the refrigerator.
Shut off the house water supply to the refrigerator.
Dispense a little water to relieve pressure in the system.
Remove the water filter.
Remove the refrigerator shelves/drawers necessary to access the filter case area.
Remove the screws securing the filter case cover/housing.
Carefully pull the assembly forward enough to access the connections.
Take a picture of every water tube and electrical connector before disconnecting anything.
Disconnect the electrical plugs from the DA97-23025A.
Disconnect the water tubing. On the push-to-connect fittings, remove any locking clip first, press the fitting collar inward, then pull the tubing straight out.
Remove the mounting screws/clips and take out the old DA97-23025A.
Transfer any clips or retainers that aren’t supplied with the replacement.
Install the new assembly and reconnect each tube to its original fitting. Push each tube fully home, then tug lightly to make sure it is locked.
Reconnect the electrical connectors and secure the assembly.
Reinstall the water filter and all covers/shelves.
Turn the house water back on before completely finishing up and carefully check every connection for leaks.
Plug the refrigerator back in.
Dispense several quarts of water to purge air from the new assembly and lines, then check again for leaks.
Pro tip: The biggest thing on this repair is the tubing. Mark the lines before disconnecting them and make sure they’re inserted completely during reassembly. A tube that looks connected but isn’t fully seated can leak once full water pressure is restored.
The parts listing identifies DA97-23025A as the 110V dual filter case assembly for this model.
If you want, I can also give you the exact panel/shelf removal sequence to physically get to DA97-23025A on the RF29BB8600QL/AA, which is the trickier part of this job.
