Repair manual
Where can I locate a repair manual for my dishwasher? The circut board was damaged and we replaced it, but it did not cure the problem. The dishwasher loaded up with water and would not cycle. It will now click to wash but will not do anything else. The circut board gets warm and buzzes.
Thank you in advance for your help.
Ken
[quote=thejeepguyonline;264339]Where can I locate a repair manual for my dishwasher? The circut board was damaged and we replaced it, but it did not cure the problem. The dishwasher loaded up with water and would not cycle. It will now click to wash but will not do anything else. The circut board gets warm and buzzes.
Ken[/quote]
Ken,
The technical data sheet is located in a plastic sleve on the back side of the lower kick plate panel, if it hasn’t been lost or removed.
It should give you most of the information you need.
What did you need to know, or what do you suspect is wrong ?
:confused: :confused: :confused:
