Repacking bottom door gasket but when I close and reopen the gasket is out of door
Brand:Frigidair
Model Number:FDPH4316ASOS
Main Symptom:Water leaking from door
What happens & when: leaking while running
If the door is thoroughly cleaned, and the door gasket continues to separate from the tub it is possible that either the gasket is worn or the tub has widened where the gasket secures in place. Is there equal resistance on the upper side of the tub compared to the top center of the tub when slightly pulling on the gasket? Also, does the track where the gasket seats look like it has equal spacing all of the way around, or is there spots that are more separated than others?
Door Seal- 8581548276014 Gasket | Genuine Frigidaire OEM In Stock
