I am replacing the pump motor assembly. How do I take out the pump base? How does the new one seat so it will not leak?
Thanks,
David
Once the wires and hoses are removed the pump is only held in by 4 locking tabs. When you unlock them you can lift the pump up and out, replacement is the same just in reverse. Here is the part info and appliance breakdown:
