Remove upper rack
I got an upper spray arm replacement, but want to know how to remove the upper basket to access the upper spray arm. Is there a release on the slide arms or do I have to remove the screws on each side holding the basket to the arms?
Larry
[quote=LTroutman;316846]I got an upper spray arm replacement, but want to know how to remove the upper basket to access the upper spray arm. Is there a release on the slide arms or do I have to remove the screws on each side holding the basket to the arms?
Larry[/quote]
Larry,
You have plastic End caps, that are clipped in place
AP6012321
You have to roll the rack out 4-5 inches and press on the outside of the rack track oin holding them in place.
Sometimes they can be a pain, but once you get them off and out, you just roll the rack out, and go about doing the repair.
Good Luck,
