Brand:Frigidaire
Model Number:Lfhd2251tf6
Main Symptom:not cooling
What happens & when: makes an intermittent noise/lights flicker on water dispenser/ no interior lights
Brand:Frigidaire
That sounds like a low voltage DC drag on the system or a failed control board.
Since the lights on the dispenser are flickering, I would disconnect the fridge from power at the outlet or the breaker and try disconnecting the user interface board 5304518822 in the front of the left door and see if anything starts working when you power the fridge back up.
Looks like you should probably be able to just disconnect the harness at the top hinge of the left door to take that user interface board out of the system for this test.
If everything inside of the fridge starts working with the left-hand door harness disconnected then you know one of the components in that dispenser area is bad.
Thanks for the reply
It’s working now. I had it unplugged for a while then plugged it in just to check & it came back on. When it stops I’ll try what you suggested.
Also- the ice maker stopped working recently so maybe that is related.
Refrigerator stopped working again.
I unplugged the harness at the top left hinge but no change.
