Refrigerator is freezing food in the fresh food compartment
All of a sudden, the food is freezing in the fresh food compartment. Turned down thormostat, still freezing. Friend suggested turning down the temp in the freezer compartment, did not help. Any suggestions?
Hi.
Based on you description the problem is with air damper control, witch is not sold separately. You will have to get
The control box assembly AP5176342
Here are the breakdown diagram and Controls replacement parts for Frigidaire FRS26HF5AB0 Frigidaire/refrigerator | AppliancePartsPros.com
It’s located in the fresh food section top left corner.
Thank you. Post the results.
Simon.
Freezer air going into refrigerator through vent that is not closing when set temperature is reached. Replace thermistors in the refrigerator.
