Kenmore side by side refrigerator is freezing celery and lettuce in crisper drawer. It seems to run constantly at the lowest setting. Changing the temperature setting does not appear to have any effect on the temperature in the refrigerator. Ice cream in the freezer side is frozen solid like a rock. Any suggestions ?
most sites that sell parts can help.
Type in your model.
On the left side you have some common symptoms like “refrigerator freezing food”
Click on that and you will get cpl parts that are usually the cause of your problem.
You can also test thermostats for continuity to make sure they are not faulty. Also chk the damper flap to make sure it’s functioning correctly. G luck ![]()
Parts for 1068472481 - AppliancePartsPros.com
Sounds like the control thermostat is not regulating the temperature.
AP6009213
Click on the picture for more info about the part.
Note that then Sears site has part breakdown diagrams, unforetunately they do not share these with other vendors.
