The handle came loose on one side- I saw a suggestion to take the panel part way off to fix it, but because of the way that the top sides of the panel fits into the grey plastic that the buttons are in on the tops, this didn’t work. So I took the panel all the way off & I was feeling pretty good about fixing the handle until I couldn’t get the panel back on. I couldn’t because even after I got the bottom sides where they go between the door and the spring hinge (quite a struggle), I couldn’t pull it up- it seemed to be caught on something.
Any suggestions? Any schematics that might show me what I’m doing wrong?
