Brand:Samsung
Model Number:RF263AEWP/XAA
Main Symptom:intermittent Pinging Noise and cycling through temp settings
What happens & when:The fridge will spontaneously start cycling through the temperature settings making a pinging noise. Water also slowly gathers in the bottom of the fridge compartment. I have removed the evaporator cover and checked that the drain is clear. Also fitted your extended metal tag mod some years ago to make sure heat is getting to the drain to keep it open. (Great mod that saved me having to buy a new fridge.) Also fitted new door seals which worked great.
Error Code (if any):None
Parts or tests already tried: checked drain was clear
