"Clean" icon blinks 7 times, stop, 7 times
Previous to the blinking problem, the motor was extremely noisy. Replaced motor through your company, however, “clean” light blinks 7 times, pause, 7 times, etc. When cancel is pussed with door closed, motor attempts discharge of water.
Replaced motor, still have light blinking..can’t reset dishwasher…HELP!
[QUOTE=keyarrow;365861]Previous to the blinking problem, the motor was extremely noisy. Replaced motor through your company, however, “clean” light blinks 7 times, pause, 7 times, etc. When cancel is pussed with door closed, motor attempts discharge of water.
Replaced motor, still have light blinking..can’t reset dishwasher…HELP![/QUOTE]
DISREGARD !!! After viewing all responses here, was able to get the correct buttons and sequence to reset:
[RIGHT]
FOR: Model Number: KUDPO1ILWH6 Brand: Kitchen Aid Age: 5 - 10 years [/RIGHT]
“Open door, within 3 seconds hit high temp scrub, energy saver dry, then repeat. Close door and press cancel.” Machine goes through two minute run and clears the electronic display. THANKS !!!
[quote=keyarrow;365861]Previous to the blinking problem, the motor was extremely noisy. Replaced motor through your company, however, “clean” light blinks 7 times, pause, 7 times, etc. When cancel is pussed with door closed, motor attempts discharge of water.
Replaced motor, still have light blinking..can’t reset dishwasher…HELP![/quote]
Did you ever get an answer? I have same problem
