Hello, I recently posted this and was told maybe a thermal fuse. I just found out that I can find reset codes behind toe plate. I will check tomorrow. I have power to the control panel but no lights or commands are responding. Is there something else I can do? Im trying to find a schematic to locate the thermal fuse, since it is one of the less expensive parts to try. Thanks, James
Please do not start a bunch of new threads as it will just get confusing.
I looked at your other post to get the model number (GU1200).
Replacement parts for WHIRLPOOL GU1200XTLS3 Undercounter Dishwasher | AppliancePartsPros.com
Fuse is Item 6 in Section 2. Remove it and check it with a meter if it is blown be sure to use the new wiring harness that comes with the replacement.
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
This should also help
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
