this dishwasher has push button panel on top of door. when i push the cycle button say “normal”, i then push “start” the “normal” button will blink one time to let me know to close the door and it will wash. Now i push the"norma", push “start” and it will not blink at me. when i let it sit for about 30 seconds(door closed or open) the normal light will just shut off . i wonder if this is the push button panel "start"button that is not working any more. please help .
Here is a tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
The usual way to troubleshoot these units is to check the keypad with a meter.
If it is OK then replace the control board.
Still a bit of a crap shoot but your odds are a bit better.
You may want to try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
