Pump gasket
According to the pump and motor parts diagram, part 16 (pump gasket) must be replaced anytime the pump assembly is removed or reinstalled.
http://www.**********************************.com/model.php?mn=KUDS25SHBS1&brand=WPL&man=&pid=109863&pmid=105119
However, the diagram does not show where part 16 goes. Does anyone know?
This gasket goes around the sump.
Where is the sump, in the drawing?
It is the bottom part of the pump which goes into the tub (#25 on the diagram).
