Puddles on floor below French Door freezer
My relatively new Maytag French Door freezer door is not sealing properly. A thick layer of ice builds up on the freezer bottom and there is some ice creap leading to puddles of water on the floor. Should I try and replace the door seal? Or, should I try a little silicone grease on the current seal first.
Is it difficult for a DIYer to change the seal correctly?
Why do you think it is a bad seal?
It sounds more like a clogged drain and the ice is from defrost.
