I am having a problem with my Dishwasher. It is a Whirlpool GU9805CGG0.
I have tested the Float Switch and it is OK,
I have tested all the buttons on the front panel and the are all OK.
I believe that I am having a problem with the control board which is a 8051136.
Symptoms
When I close the door, the dishwasher starts in Normal mode automatically. During the run time, the board turns on the China Crystal LED and it starts blinking saying that it is a stuck switch and the controls are locked.
I can cancel it, it drains but it will restart itself again and the process repeats. -
If I try to put the controller into a diagnostic test by pushing Power Scour, Air Dry, Power Scour, Air Dry the following happens - All LED’s are turned on then off. Next the dishwasher starts in NORMAL mode with Add a Dish LED turned on. I can not advance the program by pressing the Pots and Pan button, thus I believe that the program has been terminated.
I think that the CPU on the control board or the EPROM have gone bad.
Before I get a new board, I would like to get some feedback from a knowledgeable person.
Thanks in advance for any help.
