Plastic screw for upper arm assembly
Hi, my dishwasher works great, however, the big fat plastic screw that holds the upper arm to the hub broke and I have been unable to find a replacement. I was going to get the entire package but the person I chatted with said the kit includes the hub, arm and washer (which I already have) but not the screw, which is what I need.
I have tried metal screws but they do not seem to howl all the parts together.
What should I do?
[quote=Mita;323150]Hi, my dishwasher works great, however, the big fat plastic screw that holds the upper arm to the hub broke and I have been unable to find a replacement. I was going to get the entire package but the person I chatted with said the kit includes the hub, arm and washer (which I already have) but not the screw, which is what I need.
What should I do?[/quote]
Mita,
This is the upper most spray arm assembly, the one mounted to the top of the tub, correct ?
If that’s the case,
This should be the screw you’re looking for,
AP3669304
Good Luck,
:slight_smile: :slight_smile:
