Piece of the rack wheel broke-maybe in drain
A piece of the upper rack wheel broke off and fell inside the machine unknowningly. I’ve replaced the wheel parts, but the small piece may be inside the bottom of the machine. I can’t feel or see anything, but want to know if I can remove a few parts to retrieve the pieces before any further damage is done. DW is still cleaning fine, but it makes a squeeling noise when in wash cycle. Drains and fills fine. Cleaning well. (Trying not to use it for now!) Any suggestions will be greatfully appreciated~
Replacement parts for MAYTAG MDB8750AWW | AppliancePartsPros.com
Here is a service manual nad a tech sheet
http://www.servicematters.com/maytag_library/docs/16022783.pdf
http://www.servicematters.com/maytag_library/docs/16023227.pdf
If you do not have already you will probably need a set of Torx (star) drivers to open the pump up, I think.
