replaced panel control in dish washer worked fine for a couple of times. then clean light keeps blinking and i cant get it to keep blinking
Blinking clean light has nothing to do with the control panel. It shows that the control senses something wrong in the heating circuit. You have to check the heater and the high limit thermostat for continuity.
thanks gene where can i find a diagram for the heater stat marko 123
how can i find the high limit for my heating cirkit
What is the end of the model number?
complete # is kudso1flss6 i think i found it 1 orange wire goes to this part at front of dishwasher 1wire white with a purple stripe goes to wire harness going into door both wires are coming from heater the wire coming from front of door with orange wire is going to wire harness going into door its color is white and red thanks marko 123
I believe you found the right part. It’s shown as #30 on the diagram and the wires color is in accordance with the Wiring diagram. remove the wires and check the part for continuity.
- The high limit thermostat AP6010246
is that a reset button i see my part doesnt have that mine sits against bottom of tub with 2 wires coming off of it that has to be the problem the heater has continuity does the diagram show where its located thanks marko 123
This thermostat is not resettable. It is mounted on the bottom of the tub ans is shown as #30 on the diagram. You have to check it for continuity and if there is nothing wrong and there is no broken wires, then the problem very likely is a bad control board.
if its the control board what part # is it any chance of getting a diagram and parts list on my model thanks marko 123
Have you ever clicked on the link “diagram” which I posted in my previous reply at 5:15 p.m. earlier today?
- The control board AP6013336
i guess what i meant was a scematic. anyway i guess my next step is the control board. is there any way of checking that to see if its bad? thanks gene for your patience. marko 123
Sorry for the delay.
The wiring diagram (schematic) link is in the same reply.
There are only three parts in the heating circuit and they are: the heater, the high limit thermostat and the control board. If the heater and the thermostat are fine, then there is nothing else left but the control board.
