Oven Turns on briefly, and then shuts off
Brand: Kitchen Aid
Model Number:KODE500ESS21
Main Symptom: Won’t heat up
What happens & when: After you push either bake or Broil, the oven (either top or bottom) will start to heat up and then after roughly 5 minutes, it will shut off with an error code. the error code was always F8E0. Upper Err Cooling Fan Low. I read the options for what this code could be. I ordered a fan and replaced it. I did not confirm that the fan was faulty. there were time constraints to make it operational so I took a chance. After assembly I put it in clean mode for the upper oven. It started. Then after approximately an hour it shut down. Error code F5E1 Upper Err Door Latch Motor. Hmm, not good. I threw the breaker to reset. Then tried to operate the Bake feature on the upoper oven and got error Code F8E0 Lower Err Cooling Fan Low. From the diagnosis tree it suggests a new Control Board. But I’m unclear if that would be the upper or lower oven control board and i have no idea how to test to confirm. I would appreciate any ideas and or guidance. Thanks!
Error Code (if any):F8E0, F5E1
Parts or tests already tried: Upper Cooling Fan Blower Motor
Hi, I’ve attached the procedures for testing the parts and identifying whether any of them are bad. Once you go through these checks, we’ll know if one of the control boards needs to be replaced and, if so, which one.
Hello Jose- Thanks for the response and assistance. I ran the associated test as prescribed by the test procedures. I was in spec for the resistance values on pg 7 F5 inputs. On pg 10 F8 the power was at spec as well. When i entered the diagnostic mode, you could hear the relays click for the upper and lower oven high and low speed fans. very helpful feature to be able to test that with out a special diagnostic tool. The lower oven you could both hear the fans operate and feel the air exit at the bottom of the unit. The issue is with the upper oven fans. You hear the click, at the board there is power and ground, but neither fan operates. If you look at the attached test procedures you provided, on pg.10 procedures 8,9 and 10 are cut off. I completed to 7. I would appreciate if you would attach the missing test procedures. Also, from the info I’ve provided does your experience suggest what is wrong to make the fans inop? Thanks in advance. Fran
Are you still available for review and and advice? Bump for response.
