Oven starts to heat up then turns off and displays cooling fan code F8E0
Brand: Kitchen Aid
Model Number: KODE500ESS21
Main Symptom: Oven Shuts Off
What happens & when: What happens & when: After you push either bake or Broil, the oven (either top or bottom) will start to heat up and then after roughly 5 minutes, it will shut off with an error code. the error code was always F8E0. Upper Err Cooling Fan Low. I read the options for what this code could be. I ordered a fan and replaced it. I did not confirm that the fan was faulty. There were time constraints to make it operational so I took a chance. After assembly I put it in clean mode for the upper oven. It started. Then after approximately an hour it shut down. Error code F5E1 Upper Err Door Latch Motor. Hmm, not good. I threw the breaker to reset. Then tried to operate the Bake feature on the upper oven and got error Code F8E0 Lower Err Cooling Fan Low. From the diagnosis tree it suggests a new Control Board. But I’m unclear if that would be the upper or lower oven control board. I was able to get some diagnostic charts. When I entered the diagnostic mode, you could hear the relays click for the upper and lower oven high and low speed fans. Very helpful feature to be able to test that without a special diagnostic tool. The lower oven you could both hear the fans operate and feel the air exit at the bottom of the unit. The issue is with the upper oven fans. You hear the click, at the board. I checked for voltage at P5-5 and neutral and P4-4 and neutral. Both had 125.4 V. I also checked P5-5 to P7-1 P5-4 to J8-2 for continuity. Both resistance values were high at 3.2k ohms. I don’t have the rest of the diagnostic chart to complete the procedure and determine if the control board is the bad component. I would appreciate any ideas and or guidance. Thanks!
Error Code (if any): F8E0, F5E1
Parts or tests already tried: Upper Cooling Fan Blower Motor
Just making sure because this gets mixed up, when you were checking for voltage for the fans did you check that voltage on both boards P5-4/5 to P8-2 or just one of them? If it was only one of them, was it the board on the left or the right? I ask because the wiring diagram is reversed from the actual physical locations of the boards, the upper board is on the right and the lower board is on the left.
Great question. I should have been more clear. I tested both boards. They both have 120+ V for the low and high speed circuit. I need to pull the ovens all the way out and inspect the wiring and connections. The ovens are just at 2 yrs old and work great. Until they didn’t.
Good deal, the main reason I wanted to ask that is because those fan winding resistance readings are way out and I was making sure it hadn’t taken out the board as well. You’ve got voltage out so I doubt the board is an issue. What may have happened is Self Clean cooked the fan, but I would more expect that if the oven worked a few times and then had the issue after Self Clean, not on the first run after being installed.
To me this sounds like a bad fan out of the box, which does sometimes happen, if the fan was ordered from us you can contact our customer support team at 1-877-477-7278 to get that exchange started.
Hi Rory,
You were correct. It was the fan. But it was an error on my part when I installed the sheet metal covers tot he top of the oven. The adhesive to the foam strip above the fan housing had lost its stick. I thought it would hold well enough with most of it still attached and the compression pressure of the sheet metal top. That wasn’t the case. When I removed the cover to test the fan ( I was going to supply external power to it to see if it ran) I could see it has ingested the foam strip in the blades. When i freed it and retested the fan function in diagnostic mode, it worked in high and low speed. Problem solved. Thanks for your help. Hopefully someone else reads this thread and isd able to avoid the smae problem and headache I caused my self.
