Oven light flickers on and off on the oven light,I can get it to stop if i push on the top of the door but it only returns to the same problem a very short time later. Any fixes?
Most likely the problem caused by the door hinge receptacles (#7 on the body break down diagrams).
You can try to adjust them or just replace. To access the hinge receptacles you have to pull the oven for about 20" out of the cabinet.
- The part number for the hinge receptacle is [COLOR=#800080]AP3461100[/COLOR]
Here are the break down diagrams for the Jenn Air oven Model JJW9630BAB
