Hi SMIMS,
In order to provide most accurate advise I need the complete model number of the range.
Hi SMIMS,
I have a Thermador Model GSC30CVWC used range just hooked it up , oven will not work flashing F3 error code
Oven (GE Profile Double Oven Model #JTP56W0D1WW)had not used for 10 days and it developed an F7 error code that does not allow any of the keypad to be used. Clock still works fine. I have tried hitting Clear/Off key and powering down the oven but code comes back.
Any thoughts on how to fix this?
aj
aj,
The problem with your oven caused by one or more stuck pads on the control panel.
Here are the break down diagrams for the GE oven Model JTP56WD1WW
Jane,
The “F3” error code means the oven temperature sensor (#14 on the break down diagram) is “open”.
Locate the sensor plug at the control board and measure the sensor resistance. It suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong then you have to pull the range, remove the rear cover and measure the sensor resistance at the sensor plug.
If the reading is wrong - replace the oven temperature sensor.
If the reading is correct - check the wire harness.
If the sensor resistance at the control board is correct then check the plug and if there is nothing wrong - the control board has to be replaced.
The control board (aka clock) is no longer available.
Here are the break down diagrams for the Thermador range Model GSC30CVWC
My stove continuously flashes F10 as the oven heats up. Sears repair said it was a bad display. I personnally didn’t think this was right but they are supposed to be the experts. I cannot find the error codes for my model of stove 790.36679400. I beleive it is a run away temp. Because after the stove is off the code will continue to appear. Any thoughts on this is greatly appreciated.
I think this question was answered already, but does F2 mean a runaway temperature sensed for a Kenmore Classic Grille? I would give the model number or appliance number but I can’t seem to find it, it is very old however looks like mid 70’s decor.
todmngd,
If the “F10” appears while the range is in “time of the day” mode then the problem is a bad EOC.
If it appears in the “cook” mode then the oven temperature sensor has to be checked first. It could be a bad wire harness and/or sensor plug.
aulfgar,
You are right, “F2” error code on older models means “runaway temperature”.
I replace the clock timer on my frigidare wall oven ,the clock work . the buttom works , but no power to the elements
w2002s,
What was the original problem?
What is the complete model number of the oven?
the original problem had an error code -1-.I replaced the EOC, now theres is still no heat. the model # is figidare FEB24S5ABB
You probably mistyped?
the eoc were replaced .but the oven still not heating up. The clock work , buttom works. what do you think the problem is.
What was an error code shown originally on the display?
Hi Gene ,the error code on the display was -1- this is no type error
I am getting this code on my double oven. RBD276PDB12
What should I do? What parts do I need? How hard is it to do?
w2002s,
According to the wiring diagram there is a safety thermostat (#141 on the break down diagram) which, if it’s open, interrupts power to both heating elements. I’m not sure where it’s located. It could be on top of the oven (behind the control panel) or on the back of the oven.
Hi Gene I check the safety thermostat with a digital ohm meter across the two prone it displayed 00.0. do that indicate a closed circuit?
Did you disconnect wires from the thermostat prior to testing?
