Oven error codes
I have a Whirlpool double oven that is about 4 years old. While using both upper and lower ovens I lost all digital images on the control panel. Tried the breaker and no help. After two days the digital image came back on and the oven worked for a few minutes and then I got an error code of E6 & F2. We keep getting a beeping every so often so we had to turn off the breaker. Any help you can suggest would be appreciated. Also, I need to find out the best way to remove the control panel without damaging the front of the oven. Thanks again
Check this out.
Appliance Fault Codes
Nat
I recently wrote and inquired about error codes on my Whirlpool double oven. We ordered a touch control panel and my husband installed it. After one use of the oven. The oven started doing the same thing again. No digital readings, oven won’t turn on, and no clock. However you can turn on the light with the control panel.
If you have any suggestions I would GREATLY appreciate it. Here we thought wow we fixed it ourselves and for half the price of the part that the service man wanted and that wasn’t even including labor.
Double check your wire connections. Let us know if that takes care of it. If not you may need the control board as well.
Nat
