Oven display not working and oven stuck on
Brand: ge cafe
Model Number:ctd90fp2n1s1
Main Symptom: display screen went black and gray fuzzy and oven was stuck on shut off the power for 10 minutes repowered and it did the same , then left it powered down for 30 minutes and turned it back on and oven is back to normal except for a light backround flickering in the display which lasted for 10 minutes then cleared up and randomly over the past month it would shut down during a preheat cycle
Hi rgorczy,
This symptom typically points to either a failing main control board or a faulty display interface. The black or gray fuzz and screen flickering suggest the control board is having trouble communicating with the display, while the unit shutting off during preheat indicates the internal relays that power the heating elements may be failing.
I tagged a few videos below that can help you check whether the control board has failed and determine if it’s causing the problem you’re seeing.https://youtu.be/u0fiQ0mST8A
