Brand: HotPoint
Model Number: HTW240ASK6WS
Main Symptom: LID NOT LOCKING
What happens & when:not draining
Parts or tests already tried:WH08X37938
Brand: HotPoint
Since the WH08X37938 lid lock is new and the locking tab still never extends, I would not replace the lock again yet. On the HTW240ASK6WS, the next step is to determine whether the control is actually sending power to the lock.
The fact that it also will not drain can be related. The washer may be stopping because the control never sees the lid reach the locked state.
Here’s where I’d start:
Check the lid strike first. Make sure the strike on the lid is entering the new lock completely and isn’t cracked, bent, or sitting too high. Close the lid slowly and verify it physically pushes into the latch correctly.
Run the washer’s service/diagnostic lid-lock test. Listen closely at the new lock. If you hear absolutely no click or movement, we’re looking more toward a wiring or control issue rather than another bad lock.
Inspect the lock wiring and connector. Follow the harness from the lid lock toward the main control. Look especially for a broken wire, backed-out terminal, corrosion, or loose connector.
If you have a multimeter, the best test is to check whether the control is supplying voltage to the lid-lock circuit when it commands LOCK. This is a live-voltage test, so only do it if you’re comfortable working around energized wiring. If the proper voltage reaches the new lock but the tab doesn’t move, the new lock is suspect. If the voltage never reaches it, check the harness back to the control; if the harness is good, the main control becomes the likely problem.
I would also check the stored fault codes before buying anything else. On these GE/Hotpoint top-loaders, a lid-lock/feedback fault can help separate a mechanical latch problem from a control or wiring problem.
If you have a multimeter, I can give you the exact WH08X37938 connector pins/wire colors to test and what voltage you should see during the lock command.
