Only hot water dispenses even though cold water is selected Model Number:GUD27ESSM1WW
Brand:GE
Main Symptom:Can’t select cold water
What happens & when:Only hot water fills washer even though cold selected. Already replaced water intake valve.
Parts or tests already tried:water intake valve
On the main control board, locate the J514 connector. With the washer set to cold water fill, check for 120 Vac from the orange wire to the Brown wire. If there is 120 vac but the washer is dispensing hot water then replace the valve. If there is not 120 vac then the control board would be the issue.
I already changed the water inlet valve. I tested the orange/brown wires on the J 514 connector on the panel. The orange/brown connector shows123V when cold water is selected yet hot water is dispensed, not cold water. There must be another possible cause.
