One burner not igniting on gas stove
Brand: Maytag
Model Number: MGR5750ADW
Main Symptom: I have two burns not working but I hear the sparking sound
What happens & when: I replace one burned with a new spark ignitor
| WHIRLPOOL Range Top Burner Spark Igniter |
| Part #:
AP4093621 (74004053) | but this did not fix the issue. there is not spark at all for the burner. So now trying to figure out what next I need to do. I did not replace the other one since the first one did not fix the problem |
This could be caused by an improper contact, a clogged orifice or jet, a valve issue, or even a damaged wire. An easy way to check if it is something with the burner head would be to switch the burner head and igniter over to a burner where everything is working. Try using the burner head on the known good section. If it works, the burner head and the igniter are good, isolating the possibility to either an issue between the valve to the orifice, or an issue with wires. The orifices can be visually inspected for any clogs at the output side. Let me know what you find and we can go from there.
The orifices are working correctly; all the burners work either by turning knob to light or using a match to light it. It’s when you turn the gas knob that it will not ignite the one burner that not working.
Just thinking it maybe the wiring when you turn the gas knob on that it’s not working correctly
If you switch a burner head from a side that is not working, over to a side that is currently working, does the failure stay at the same spot or does the failure seem to move with the burner head? This will help identify where the specific failure point may be.
