Old Maytag Dishwasher not releasing soap
My very old ( more then 20 years) Maytag dishwasher is not releasing soap out of the tray during the cycle. The serial number for this make is L62239 LJ
I am trying to diagnose if it the whole soap dispenser that is broken ( which they do not make anymore) or if it just the tray.
Please help
Sophia
Hello sophiaann. You will need to test and see if there is power coming to the bi-metal when the dispenser is suppose to open. If so, and the bi-metal is not working properly, then you have a bad bi-metal. You can test this with a multi-meter [AP3873826]. Here is a link on how to use a multi-meter. Hope this helps.http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
AP4111544
Door assembly replacement parts for MAYTAG WU701 DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
