Brand: GE
Model Number: GTW845CPN0DG
Main Symptom: doesn’t complete cycle
What happens & when: Ends wash cycle before it spins.
Error Code (if any): none
Parts or tests already tried: control board replaced
Brand: GE
Since you’ve already replaced the control board on your GE washer GTW845CPN0DG, and it’s still stopping before the spin cycle, I’d focus on the drain system, lid lock, and motor-related components before replacing anything else.
Here’s what I’d check next.
1. Check the drain system. When the washer stops, is there any water left in the tub? If so, check the drain hose for restrictions and listen to see whether the drain pump runs. If the washer can’t drain properly, it may never advance into the final spin.
2. Check the lid lock. The washer must confirm the lid is locked before entering high-speed spin. Listen for the lid lock engaging. A faulty lock or loose connection can prevent spinning even with a new control board.
3. Try a Drain & Spin cycle. Start this cycle with the tub empty. Watch whether the washer drains, locks the lid, and attempts to spin. If it drains but never spins, we can narrow the problem to the lid lock, motor system, or related wiring.
4. Check for stored fault codes. Even if no error appears on the display, the control may have stored diagnostic codes that can help identify the failure.
5. Inspect the motor and drive system. If the lid locks and the washer drains but the basket doesn’t turn, the next step is checking the motor, drive components, and wiring. Unplug the washer before inspecting these parts.
Those answers will help us determine whether we’re dealing with a drain problem, lid lock issue, or something in the motor and drive system. Since you’ve already replaced the control board, I’d rather narrow it down with a few tests before recommending another part.
Thanks for confirming those details! That helps narrow things down quite a bit on your GE washer, model GTW845CPN0DG.
Since the washer is completely empty when the cycle ends, it sounds like it’s draining properly. And because it spins and drains when you manually select Drain & Spin, we know the motor and spin system are capable of working.
The lid also unlocks normally, so I wouldn’t jump to replacing the lid lock.
I’m leaning toward a problem with the washer advancing through its automatic cycle, rather than a mechanical spin failure.
Since you’ve already replaced the main control board, I wouldn’t replace any more parts just yet.
Here’s what I’d check next:
That distinction will help us narrow down what to test next.
Is this conversation helpful so far?
This has been very helpful. thanyou
It reads codes: 26 27 66
Thanks for checking those codes. That gives us a better direction for your GE washer, model GTW845CPN0DG.
Since the washer completes the rinse, skips the final spin, and goes directly to END without flashing any lights, I wouldn’t replace another control board just yet.
The stored fault codes are:
The important thing is determining whether the washer is skipping spin because of a balance issue, a water-level reading, or a problem with the spin command.
Codes 26 and 27 are documented in GE’s top-load diagnostic information. Code 27 specifically relates to water remaining in the tub with the lid open for an extended period, so it may be a stored event rather than the cause of this failure.
ManualsLib+1
Two questions that will help narrow this down:
Those answers will help us determine whether the washer has a mechanical spin problem or is ending the normal cycle before commanding the final spin.
That helps a lot! Since your GE GTW845CPN0DG drains completely and spins at full speed when you select Drain & Spin separately, we can narrow this down considerably.
The motor, drive system, and drain pump are all capable of working properly. I wouldn’t replace any of those parts right now.
The problem appears to be that the washer is ending the normal wash cycle without commanding the final spin.
With fault codes 26, 27, and 66 stored, I’d focus on why the control is deciding to skip that step.
Here’s what I’d like you to try next:
Check the spin-speed setting. Select a normal wash cycle and make sure the spin speed isn’t set to No Spin.
Run a small, evenly distributed load. Use several similar-sized towels rather than one bulky item. Watch whether the washer attempts to balance the load before displaying END.
Inspect the suspension. Even though Drain & Spin works, a weak suspension system could trigger an out-of-balance condition during a normal cycle.
Check the stored codes again after the test. If code 26 returns, that strengthens the case for a balance-detection problem. Code 27 may simply be from an earlier interrupted cycle.
Sears PartsDirect+1
One important question: When the rinse finishes, does the basket make any attempt to spin, even briefly, before END appears? Or does it drain and immediately display END without the basket moving?
That distinction will help us determine whether the control is attempting the final spin and stopping it, or skipping it entirely.
I’m not near the washer, so i will try those other tests tonight and reply tomorrow
I went and unplugged machine for a longtime. Couple of hours. And i dont know if that cleared the old codes after putting in new control board, but everything is working as it should be
