Not running
Can’t figure out what’s wrong with this machine.Everything seems to be working, LED’s, it fills,water heats up, counts down the cycle time, it drains. But the motor, not a peep out of it.Just replace it a bout 6 months ago and was working great til now. I read in someones post that the motor can be be jump started with just a simple spin.
Any advice on how to get it running will be greatly appreciated.
THank you
Pump and motor parts replacement parts for WHIRLPOOL KUDS01DLSS2 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Tech%20Sheet%20-%208537797.pdf
Remove power from the unit, remove the kick plate and try turning the motor’s armature using the cooling fins at the back of the motor.
If it does not turn the motor is jammed and you will have to open up the pump to find the cause.
If it does turn check the motor’s windings for continuity.
If OK check to see if it is getting power when it should (120 volts)
