Not Operating
Hi Folks,
I have an UltraQuiet 2 dishwasher. Rarely used prior to 2 years ago, then only 2x per week. Unit does not operate at all. Wondering if it is the timer or swith selector. Removed the front top panel and all parts are clean, free of moisture/dust/corrosion as is below kick plate. Door latch engages with striker plate and neither are loose nor damaged. Control knob ratchets but no power light. Breaker is not tripped. Any help would be greatly appreciated. New one will cost upwards of 1k. Thanks!:confused:
Replacement parts for FRIGIDAIRE FDB435RFR4 Frg(v0) | AppliancePartsPros.com
You will need a meter.
Check that there is power to the unit.
Sometimes there are problems with the wire nuts that connect the unit to power.
If power is OK check that the door switches are OK.
If you have no experience working with electrical you may want to get a pro in.
FDB435.pdf (1.1 MB)
