I have late model Whirlpool Gold Ultimate Care 2 electric dryer and as of tonight it has STOPED heating. I will admit for the past 4-4.5 years the wife runs it AT LEAST once a day. Just wondering if there is anything else that could be wrong with it other then the heating element. Thanks Guys..
It could be 1 of 3 thermostats also, I’ll bet on the thermostat at the top of the heater box.
How would I go about seeing if either of these thermostates are good or bad… Thanks
Test them with a volt-ohm meter, if you don’t have access to one, you can pick one up for under $20 Test all Thermostats and you should find the bad one.
