Normal wash light blinking
Normal and cancel light blinking continuously. Seems like some wire might have gotten hot? What should I look for I am against calling a tech out… Please help
I am having the same problem, my cancel light is blinking and nothing else will turn on, mine is a Kenmore, did you have any luck yet??
dirtdishes1970
Model Search
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
Tech sheet includes how to interpret lights, run diagnostics and also how to test the keypad for a stuck key using a meter.
First thing to try is remove power to the unit for half an hour or so just to see if it will reset.
kim ache
Please start your own thread using “Post New Topic” in this forum.
Be sure to add a Model Number, your problem may be totally different.
I have turned the power off for the evening and it still does not work. Thanks
