I have a Whirlpool GU2500XTPB7 dishwasher. I was having intermittent problems with it not pumping out, and I would open and reshut the dishwasher and it would start and finish the whole cycle.
Yesterday , it did they same and then would not drain. I chose the drain and cancel. It drained and then I got 1H code which I took for a 1 hour delay.
I turn off the circuit breaker overnight
now the normal light flashes… If I turn the circuit breaker off, and back on it then have the number 2 in the timer and starts trying to drain.
My significant other is handy with repairs , sure wish someone would reply.
There are no tech notes in the kick panel. Do you have tech notes for this dishwasher.. older post link to tech notes not working.
Can you give me a clue as to what is happening??
I thought it might be the door latch, drain air gap, or a fuse. :eek:
