Brand: GE
Model Number: PSS26NSWASS
Main Symptom: Noise
What happens & when: There is noise on the fridge side, sounds like a motor with a bad bearing. However this fridge does not have a motor on the fridge side except for the custom cool motor, which is not running. I suspect somehow the damper assembly is responsible for the noise. Any feedback on this?
Parts or tests already tried: I replaced the evaporator fan motor. The condenser fan motor and compressor are not noisy when running.
