No water
Dish washer working fine. Next load ran thru cycle ok, when opened dry soap at bottom and dishes still dirty. Checked other cycles rise, heavy duty, ect. same issue – no water. Checked supply line & hose all ok. Any info on common concerns? Diagram on how it works? Electrical problem? How about a valve or screen?
I tried search feature nothing on this model but found no info.
Thanks in advance for any info.
Replacement parts for WHIRLPOOL SUD5000KQ0 | AppliancePartsPros.com
[COLOR=Blue]Any info on common concerns?[/COLOR]
Could be one of the following:
Overflow/float. Check that the float is not stuck in the up position. Switch should be closed, check it with a meter.
Valve filter screen. Remove the valve and check it. If it is clogged up clean it. Do not remove it as it is there to keep crud out of the valve, which could hold it open and cause a flood. Also a good idea to drain some water out of your hot water tank as crud collects in the bottom of the tank.
Valve itself. Check that it is getting voltage when it should (120 volts). If yes and the filter screen is clean the valve is shot.
Controller. If the valve is not getting voltage and the overflow/float switch is closed, could be the contacts in the timer are shot.
Bad wire. Check the wires from the valve to the control for continuity.
Cannot find tech info on this unit but perhaps the following will help.
http://www.applianceaid.com/dishwash.html
