No water
water does not get into the dishwater. would this be because imput selenoid is bad?
Part Number: [COLOR=#0000ff]AP4295099[/COLOR] made by WHIRLPOOL $3.82
Out of stock
Usually ships within 5 - 6 days
[SIZE=2]5 [/SIZE]
[COLOR=#810081]Enlarge Photo[/COLOR]
[COLOR=#810081]Solenoid-[/COLOR]
Part Number: [COLOR=#810081]AP4110932[/COLOR] made by WHIRLPOOL
this picture is the drain solonoid ,it has nothing to do with water coming in .the water valve is probably at front left corner behind bottom panel ,check to see if either water valve under sink is turned on ,or you are gettig 110 volts to water valve
