No voltage at water control valve but valave is okay
This Machine Goes On But Will Not Fill With Water. Water Inlet Valve Is Working When 120 Volt Is Applied And Test In Good Working Order. “machine Goes On” When Machine Is Turned On There Is No 120 Volts Going To/at The Water Control Valve. When I Apply 120 Volts To Control Valve, Machine Fills And Starts Washing But Does Not Cycle, Just Continues To Wash And Never Stops Washing
[QUOTE=JOEYCASH;898601]This Machine Goes On But Will Not Fill With Water. Water Inlet Valve Is Working When 120 Volt Is Applied And Test In Good Working Order. “machine Goes On” When Machine Is Turned On There Is No 120 Volts Going To/at The Water Control Valve. When I Apply 120 Volts To Control Valve, Machine Fills And Starts Washing But Does Not Cycle, Just Continues To Wash And Never Stops Washing[/QUOTE]
SOUNDS LIKE THE CONTROL BOARD
THIS MACHINE GOES ON BUT WILL NOT FILL WITH WATER. WATER INLET VALVE IS WORKING WHEN 120 VOLT IS APPLIED AND TEST IN GOOD WORKING ORDER. “MACHINE GOES ON” WHEN MACHINE IS TURNED ON THERE IS NO 120 VOLTS GOING TO/AT THE WATER CONTROL VALVE. WHEN I APPLY 120 VOLTS TO CONTROL VALVE, MACHINE FILLS AND STARTS WASHING BUT DOES NOT CYCLE, JUST CONTINUES TO WASH AND NEVER STOPS WASHING
