Dishwasher not cleaning dishes or soap out of tray. I installed a new inlet valve that did’nt fix the problem. any help out there:rolleyes: :rolleyes: ???
Replacement parts for MAYTAG DWU6750AAB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Here is a manual although it does not show your unit I believe the pump is the same.
16007823 Maytag Dishwasher Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Could be just the pump needs cleaning out re: filters and chopper /impeller.
Most units fill to just below the heating element.
If you are not sure that iot is getting enough water even with the new valve you could add a quart or so of water after each fill. If it then runs OK you know that you have a fill problem. Just be careful that you do not overfill the unit.
