:eek: :eek: [FONT=Arial Black][SIZE=4][B]HELP !! If I don’t get this fixed soon… I’ll have to do the dishes… It’s almost playoffs…I have a Kenmore dishwasher Model #17519201. There is no pressure to the upper washing arm under the upper dish rack.
It has a pipe that runs from the pump at the bottom of the unit, up the back of the inside of the dishwasher.When you push the upper rack in to close the door it seems the under rack spray arm seems to couple to that rear pipe. Is there a bushing, gasket etc. that is supposed to make a water tight connection when the rack is pushed in? It would seem to be missing. Is there a part number or a way to find an exploded view of that section so I can order it?
Thanks,
AL[/B][/SIZE][/FONT]
