No lights
changed mother board still no lights come on control panel
Replacement parts for KENMORE 66513242K900 | AppliancePartsPros.com
Did you check/replace the fuse on the control board.
AP4423189
Click on the picture for more info and a Q&A on it.
If it is blown be sure to use the wiring harness when replacing it.
Did you check the door switches?
