hi , my dishwaher machine have 3 cycles of washing , the machine take water and at then end of the fill, when suposed start, drain the water , this hapen in the 2 out the 3 cycles , please any sugestion
Can you double check your model number so we can look at a breakdown please.
Thanks for the the respond, the model is KUDS25SHBLO
That model number doesn’t pull up. Did you get that off the machine?
Nat
yes the information is at the side of the tub
the only i cant think that the last is a "C"not a 0 so the model will be KUDS25SHBLC
[COLOR=#0000ff]KUDS02SRBL4[/COLOR] this is the closest model I can find to the one posted.
I think will ok
Just to add my 2 pennies… Most likely the problem is a bad control board.
- The part number for the control board is [COLOR=#0066cc]AP3175633[/COLOR]
nleal61122, your mistake was: when you typed the model number you put “O” instead of “0”. Thats why libertyappl’s computer could not find it.
Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDS25SHBL0
