because I have dumped a cup of water in the ice maker and it made ice cubes. So that makes me think it may be something with the water coming in?
I still can not get my ice maker to work and I don’t know what to test next.
can you please walk me through how to test the water intake. I know it has water flow going to it but it never turns on to put the water in the icemaker itself.
Here’s a video that explains how to check the valve. Let me see if I can find anything else that might help https://youtu.be/F4uMYr7CTpw?si=OSDoGMi7nr3xboWS
First, disconnect the water supply line from the refrigerator and place the end into a bucket.
Turn the water supply on briefly and evaluate the flow:
A strong, steady stream indicates your household water supply is adequate, and the problem is likely inside the refrigerator.
A weak or trickling stream suggests a restricted water line, clogged saddle valve, or faulty household shut-off valve that should be corrected before continuing.
Next, check the refrigerator’s water filter:
A completely clogged filter can stop water flow to the dispenser and ice maker.
Remove the filter and test the dispenser again. If water flow returns, replace the filter.
Also verify water pressure:
Most refrigerator water valves require a minimum of 20–30 PSI to operate correctly.
Low water pressure can prevent the valve from opening fully.
To test the water inlet valve:
Disconnect power to the refrigerator.
Remove the wires from the valve solenoid terminals.
Set your multimeter to the lowest resistance (Ω) setting.
Touch one probe to each solenoid terminal.
Expected reading:
Most inlet valve solenoids should measure 200–500 Ω.
Some Whirlpool models may read closer to 100 Ω.
Failed valve indications:
OL / Infinity / No continuity = open coil, replace the valve.
0 Ω or extremely low resistance = shorted coil, replace the valve.
A reading far outside the manufacturer’s specification indicates a defective solenoid and the valve assembly should be replaced.
