New Dryer Motor
Installed new motor AP3094233. When I tryed to turn dryer on it would not come on. Plugable motor switch plugged in and everything lined up.
The wiring harness has different colored wires than in the instructions. Wirng harness consists of 2 red, 1 blue, 1 green, 1 white. Any suggestions?
See the attachment for the machine’s wiring diagram.
Here is a good link which may help.
http://www.applianceaid.com/279787.html
68932792.pdf (173.6 KB)
Thanks so much for your help. The information you gave me was exactly the problem. I attached the short blue wire as you suggested and also attached the long blue wire to the belt sensor. It started right up as soon as I pressed the button! The instructions that came with the new motor were not much help… Once again, THANKS!!!
You are welcome
Glad to hear you got it up and runnuing.
